blinker relay
'Bird Director
Just undo the trim panel that's under the steering wheel. You'll see the flasher relay on the right side. It will probably be tucked in behind the center console a little.
I reached in from behind the center console the first time I changed it. I learned my lesson the second time and removed the trim panel underneath the steering wheel. Dropping the trim panel underneath the steering wheel is definitely the way to go.
