Piecing rotating assembly, have a question.
I wasn't sure how to title the question. Anyhow, I am buying the parts to build my motor piece by piece and then once I've got everything, I plan on taking it to a shop to do the machining and balancing. I won't buy the pistons because they will be custom and I'll leave that up to the engine builder to decide. My question is, would I be safe to buy the crank and connecting rods before hand? I don't think there's anything custom/special about these pieces, but I could be wrong. I figured they were standared parts of a rotating assembly. I wanted a set of Callies Compstart connecting rods and the common size seems to be 6.125" length, 2.100" crank pin, and .927" wrist pin for the LS1/LS2 engine. Then either the Callies Dragonslayer or Eagle 4"/2.100" pin crankshaft. Do I need to wait on these parts for the builder to order or are these standard sizes?
i'm pretty sure that is the standard size.since your pistons are going to be custom they may or may not have to be special made but with a combo like that you may be able to find a high quality piston that is mass produced .i guess it depends on what all you want done to the piston.
I won't be financing it. I'll be paying cash for everything. However, since I'm doing it this way, I want to save as much money as possible which is why I'm trying to piece it together myself, then have the shop do their part.
