Cam install, need some help...
Everything is going good so far except that I found 1 needle bearing laying in the top of the head. Well anyway I was in a panic so I ordered some Comp Camps Pro-Magnums from Texas Speed. Well I think I might have made a mistake going with that brand.... I don't know how to adjust the RR's and I don't know what I should do now. How hard are they to adjust?
Should I get a diffrent brand? I need somthing that will fit under the perimiter bolt valve covers. What ever I need to get.... I need them asap!
What say you?
What say you?
I think you should have gotten harland sharpe rebuilds
I also think you should check your oil pan with a magnet to find if there are any more needle bearings hanging out in there. (Assuming the rocker lost all of its bearings)
