Recommended Maintainance?
I just purchased a '93 Trans Am with some mods already installed and a brand new opti... What maintainance steps should I take? What parts should be replaced "just incase"?
Thanks.
Thanks.
Oil, Tranny fluid, rear differential fluid, coolant flush and refill,... check for shavings in the first three and corrosion in the radiator while your at it. A little late since you already bought the car but, gives you an idea of anything could be needing serious attention down the road.
New opti you say? Was the coil replaced too? New plugs and wires?
Could flush the brakes and power steering systems too.
