Messed up trans lever button?????
Old 11-10-2006, 10:33 PM
mannys_z28's Avatar
Default Messed up trans lever button?????
OK this is starting to anoy the crap out of me!!!! Every time, I go to drive my car, I have to really lean on that button on my gear shifter *** to get my car into gear . I don't think it's a transmission problem. someone told me to re-lube the cable that connects to it....
Old 11-10-2006, 10:40 PM
taintedmeat's Avatar
Maybe take the top off your shifter and see if something is broken internally. Maybe it just needs to be lubed.
Old 11-10-2006, 10:44 PM
GOaT Cheese's Avatar
At some point it its illustrious life, someone probably spilled coke or coffee, and it has gummed up the works. Take about half a can of WD40 and spray it down inside the button while spraying. It will probably take care of your issue.
mannys_z28's Avatar
it comes off??? damn! it has this leather wrapping around it. I have pic of it coming soon.. The button is on the left of the handle, to be pressed by your thumb, like a pilot throttle stick..
