rocker removal
rocker removal
im doin alot of work on my car while my tranny is being built, one thing is checking my pushrods and changing my valve seals. I need to remove my rockers but dont want to just start taking the bolts out. My question is do I need to put the cylinder im working on to TDC?
ya i know that when im removing the locks from the prings to have that piston at TDC, but wasnt sure about the rockers since a few are inbetween open/close events
well i got em out with no problems, and good news my push rods werent bent. they are 7.400 in length is that right? im using stock rockers and a F13 cam
My advice is to get a push rod rod length checker $20 from sponser. The 7.4 are probably fine but you will be amazed how quite your valvetrain will be with the proper length. Send me a PM if you want more info on using the PR length checker.
J.R.
J.R.
