pcv vacuum leAK
Old 11-11-2006, 11:38 PM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
Default pcv vacuum leAK
IS IT NORMAL RIGHT BEFORE THE PCV LINE connects to the throttle body for there to be like a small hole in the line that sux air?
Old 11-12-2006, 11:02 AM
LS1Tech Sponsor
anybody
Old 11-12-2006, 12:04 PM
melchoir's Avatar
There should be no holes in the line sucking in air.
Old 11-12-2006, 12:38 PM
LS1Tech Sponsor
thats what thought but my buddies has it in the same place
Old 11-12-2006, 07:54 PM
=ZoomZ='s Avatar
I think the guys at GM thought it would be funny to use a biodegradable hose leading to the intake ,, haha
Old 03-01-2007, 02:48 PM
texasbaseball99's Avatar
I have this same issue. It got so bad that the car wouldn't start. I wrapped it with duck tape, but maybe I need to replace it.
Old 03-01-2007, 03:21 PM
((((((Administrator))))))
CRAGER's Avatar
The vacum leaks you guys have will set off SES lights and cause your car to run lean.
Just go to a parts store, pull off one of those hoses and ask them for that size but in heater hose tubing. Its stronger and made for higher temps.
Peace,
Craig.
