SLP Timing Chain to loose???
That looks fine, chains by nature are designed to run "loose", not banjo tight. Besides, what exactly would cause this issue? The sprockets are fine, yes? The chain is new, yes? The chain is has the correct number of links, and is appropriate for your application, yes?
