Need help FAST Rollmaster degreeing cam
Old 11-13-2006, 09:17 PM
1BAD02WS6's Avatar
Default Need help FAST Rollmaster degreeing cam
ok I dont want to install this wrong and I cant get a for sure answer out of my head so please help
the CRANK spocket has 9 slots. if the center slot was at 12 o'clock which way would be to retard? this is if your looking at it as if it was on the crank.
I think the slots to the left are to retard the cam but not for sure.
Im tring to retard my cam 6 degrees so I need to move over 3 slots.
PLEASE HELP!!!
Old 11-13-2006, 10:46 PM
ArcticZ28's Avatar
I saved this just for times like these...
http://www.romac.com.au/pdf/Std%20&%...ank%20Info.pdf
And if that doesn't hit home, the simple answer is:
Rotating it counterclockwise is retarding it.
Rotating it clockwise is advancing it.
The crank rotates clockwise if you're looking at it from the front of the car when the engine is running.
Old 11-13-2006, 11:41 PM
1stz06's Avatar
I think what he really needs is more cow bell!!
Sorry that was off topic but funny as hell!!
Old 11-14-2006, 12:35 AM
BOWTIE's Avatar
Just be careful, if the LS series uses the offset style crank gear that you do not line it up with the mark denoting the keyway slot instead of the alignment mark.
Old 11-14-2006, 01:00 AM
ArcticZ28's Avatar
There should be two dots on the rollmaster crank gear, you will want to use the right-most dot for reference, as shown in the 2nd box.
