how do i go about picking injectors?
Old 11-24-2006, 08:14 AM
SSilverSSurfer's Avatar
Default how do i go about picking injectors?
stock cube with a TTi street kit anda T76, little to no street use(if that matters) thanks for the help
Old 11-24-2006, 11:58 AM
DJ's Z's Avatar
Do the formula and you'll get a close approx of what you'll need...
http://www.iroczone.com/calcs/injectorsize.htm
Old 11-24-2006, 01:52 PM
thanks...do i leave the other numbers alone and just select turbocharged? and estimated horsepower?
Old 11-24-2006, 03:03 PM
Fire67's Avatar
No that calc is only for finding out a specific injectors flow when you raise the fuel pressure above what they are rated at.
Here's a website that publishes the formulas, and a few calculators, just scroll to the bottom http://www.rceng.com/technical.htm
HP in that formula needs to be the max expected flywheel hp, or the max hp you expect your injectors to support.
BSFC should be around .625-.65, I used .6 for my supercharged setup with good results.
Once you figure injector size, the complicated part comes in with fuel pump and line size selection.
Old 11-24-2006, 03:18 PM
Smearin's Avatar
60-65 lb injectors
Old 11-24-2006, 06:08 PM
thanks guys,
Old 11-24-2006, 10:39 PM
DJ's Z's Avatar
Thats the site I was trying to find...! Thanks Fire67. Pretty sad since the 75# RC's are what I'm running...
Quick Reply: how do i go about picking injectors?
