? about converter
Old 11-26-2006, 04:37 PM
01blackz28's Avatar
Default ? about converter
Hey guy i got a 95 camaro that im doin alot of work to. Ls1 swap with a TH350. The thing i have left to buy is a converter. The tranny is built trans brake and everything. Im tryin to get the car as light as possible cuz i wana go for the cam only record.I want to beable to drive on the street. I wana know what size converter i should go with 8" or 9" and the stall i should be thinking of along with str. Im running the TTP equalizer v.3 cam. (That may change to a Trex).
Old 11-26-2006, 10:36 PM
FLT
FLT's Avatar
I would probably contact yank or percision with some spec's on your car. They will probably be able to point you in the right direction. Vince
