Tranny acting up
Old 11-26-2006, 07:15 PM
avengedws6's Avatar
Default Tranny acting up
Im not really sure what is going on, but if Im in OD, and I nail it,after downshifting and building up speed and rpm again after nailing it, my tranny wont shift back up again it just redlines. But if I do a dead stop run it shifts fine, maybe alittle late but it dont redline or ride the rev limiter. Not sure, but Im thinking my tranny needs a re-build.
Old 11-26-2006, 08:08 PM
LS1Tech Sponsor
performabuilt's Avatar
you are probably in the early stages of 3-4 clutch failure and a rebuild or replacement trans is in the not to distant future
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-26-2006, 09:51 PM
FLT
FLT's Avatar
Are you getting any codes? Also how does the fluid in your trans look? Is this a new problem? Do you run a high stall tc? Lots of questions I know but this will help me figure out which direction to point you in. Vince
Old 11-26-2006, 09:55 PM
02 BLK WS6's Avatar
A stock tranny doesn't hold up well to any punishment.
Old 11-26-2006, 10:07 PM
LS1Tech Sponsor
true ----
__________________
Call 888-744-6542
