for those of you with valve cover breathers
how many of you are running a valve cover breather on the passenger side only? by this, i mean you deleted ALL pcv lines (including the one connecting the valve covers in the back) and left the plug in the back of the driver side valve cover like it was. the reason i ask is because i called to order the breather, and the guy tried to sell my one for the driver side also. by some of the threads i read, i didnt think i needed it.
That's what she said...
I only run one, you don't need two. If you did, you probably have some valves laying in the combustion chamber. I do run a line from the driver side to the passenger side, but it's only because I didn't have enough plugs.
It's the Metco from Thunder Racing. I would drill a hole in my oil cap and run an Oriley special if I did it over again.
