CAM install questions?
Hi, This going to be my first cam swap in my 99 LS1 TA M6 and I was wondering will this cam setup pass CA smog? I'll be using my stock 99 ls1 heads and will be using 03 zo6 springs and maybe ls6 intake. Also, what lenght pushrod should I be using with this setup? here's the specs of the cam :equivalent of GM's 'Hot Cam' part# 24502586:Grind Number# HR-279-CSB
Valve Setting:
IN./Hyd.
EX./Hyd.
RPM Operating Range:
1800 to 6600
Duration:
Advertised IN./.275 EX./.287
@.050" IN./218 EX./228
Valve Lift:
1.7 Rocker: IN./.558 EX./.558
Sprins: LS6 or equivalent
Lobe Sep. Angle:
IN./116
EX./116
PLEASE HELP ME!!!
Valve Setting:
IN./Hyd.
EX./Hyd.
1800 to 6600
Duration:
Valve Lift:
Lobe Sep. Angle:
IN./116
EX./116
PLEASE HELP ME!!!
