383 Stroker Bearings
I have to replace my bearings on my 383 Application, just wondering if anyone uses anything else but Clevite 77 series..let me know what you guys use, and some part numbers would help.
I have the H series and seem to be holding fine considering I have not sprayed the thing yet.
It is going to depend if you have a standard crank or turned it.
You have standard, .010, .020, .030 under. The under is the amount removed from the crank. I also have the full grove.
http://store.summitracing.com/egnsea...115+4294870443
Here are some choices.
The rods, it is the same thing as the mains.
http://store.summitracing.com/egnsea...115+4294870491
I stuck with the Tri-Metal ones.
