Billingsley Manual brake kit ?
I just ordered this and was wondering if a proportioning valve is suppose to be used with it. I would think so but I would also have thought they would sell one if it was needed to complete the kit?
LS1TECH Sponsor
I am not using one either. The master is set up so that it is not needed. I am still using the factory brakes. Will be swapping to Strange brakes over the winter.
you dont need a proportioning valve unless your running lightweight brakes on the front or rear with stock on the opposite. If you have all stock or all aftermarket then your fine.
