Using rubber fuel hoze on this? (purge solenoid)
I think this is the fuel purge solenoid
Is there any reason I can't use this 5/16th rubber fuel line hose I had left over from some other stuff on this connection?
The stocker is not quite big/flexible enough to make it and not look janky, and I had the extra hose left over and thought it looked better.
The stocker didn't seem airtight and I was wondering if that was for a reason and that this hose would be too tight for its purpose.
Any comments would be appreciated
Thx,
DJ
Thx,
DJ
Kleeborp the Moderator™
The hose just needs to fit...the solenoid isn't open all the time, so I wouldn't worry about it either way. I don't even have the solenoid on mine anymore...I just vent straight from the hardline through some rubber hose to a small filter. The nipple on the manifold is capped off.
Thanks man.
Starting the car after my first cam/intake install today, im pumped.
DJ
