When should I change valvesprings?
Sounds like a stupid question....and I know the typical answer...but
I have had the same valvesprings since Nov. 2003 (comp 977 duals w/comp r lifters)
I only have like 5k miles on them though. Should I be worried at all?
I that it usually comes down to the amount of heat cycles they have gone through, but I did not know what would be the best in my situation.
Thanks in advance!
Mike
Thanks in advance!
Mike
Originally Posted by Slowhawk
They are 3 years old and have 5k miles on them? I'd think about changing them because it looks like the car sit's for long periods of time. Letting the sit for months at a time wear out valvesprings faster than driving it every day.
Originally Posted by zspot98
If it does sit for month's (winter storage) would it be a good idea to loosen up the rocker arms to tension off the springs?
I've been told by a tuner that a good rule of thumb is to change them every two years or 24,000 miles if you don't want to test them.
I will be getting a tune soon, and they said that they will check for any float.
