low vacuum
Old 12-13-2006, 01:39 PM
FL Junkie's Avatar
Default low vacuum
ok still trying to figure out whats wrong with my car after the cam install. ive narrowed it down to vacuum problems. i put a vacuum guage on and im reading only 5 to 10 at idle. a coworker is telling me that it should be more...less with a bigger cam but more than than. normal stock is 17 to 22. i checked the vacuum straight off the intake and at one of the lines. its the same reading.
ive had problems with it running rich and every time i take it to tune he tunes it and it goes back to rich at idle.
it looks like with the less vacuum its dumping more fuel in.
another coworker thinks i used the wrong size pushrods. i used hardened 7.4s same as stock. he is saying the valves are too tight, because of the pushrods being too long, and not opening right and as a result less vacuum.
any input on this? comp 236/244 .580 on a 112. mods are in the sig. should i have gone with 7.3s?
Old 12-13-2006, 01:57 PM
2002 SS #476's Avatar
Low and steady vacuum can be caused be retarded (cam or ignition) timing. That's a lot of duration on your cam, which will cause a low vacuum reading. With the valves being open longer, and more lobe separation, it won’t pull as strong of a vacuum.
What does the needle look like? Steady, fluctuating…
Old 12-13-2006, 02:45 PM
FL Junkie's Avatar
Originally Posted by 2002 SS #476
Low and steady vacuum can be caused be retarded (cam or ignition) timing. That a lot of duration on your cam, which will cause a low vacuum reading. With the valves being open longer, and more lobe separation, it won’t pull as strong of a vacuum.
last time i cranked it, it stayed steady at 9 at idle.
Old 12-13-2006, 03:01 PM
FL Junkie's Avatar
isnt there a way to check your rods by taking covers off, and twisting the rod to see if it is to tight?...the twist test.
Old 12-14-2006, 08:51 AM
FL Junkie's Avatar
any more advice? has anybody with a large cam in their car taken a vacuum reading?
Old 12-14-2006, 10:26 AM
Z'mnypit's Avatar
Alot of your reading is going to depend on RPM, what rpm was the car idling at? Was it a steady RPM or a back and forth RPM (like at my house)? Seems like people with cams around 750-900 rpm read anywhere from 9-11. When bone stock I think its around 15-20. I dont see how he can tune it, then it just goes back rich. that just doesnt make any sense to me.
Get a PR length checker and try that, Make sure you dont have any leaks, Maybe the TB is cracked to far open, or the hole isnt drilled to large. Just a couple things to check...
Old 12-14-2006, 10:48 AM
FL Junkie's Avatar
idles at about 950. its steady once it finds its idle. i ordered a pr length checker from comp. we'll see what that turns up.
Quick Reply: low vacuum
