Need help with radio going on and off, etc.
The radio will go off and on from time to time and when that happens, my window will not roll up or down. My antenna motor is not working, the motor runs but the mast is stationary. I know that the radio will stay on when I take the key out and goes off when I open the door like it is supposed to do. My radio is aftermarket. The new one is doing it. The old one was doing it also. It is wired correctly. Nothing is loose. It does not happen all of the time. It does not make a difference if the tempature is hot or cold outside. Sometimes it does it over and over and over and drives me nuts!Anyone got any idea's?
that sounds weird, maybe a relay or a short somewhere in the harness, under the dash is the only place I can think of where the radio wires and the power window wires would get close to eachother.
mine does that, not the window, but it does go off and on and right now the only sound i get is from my subs, amp isnt on or any other speaker, nothing is loose. *but* when i pinch my big blue wire, it comes back on, my wire is bad, needs replacement, not a big deal. good luck. wires are a bitch.
