what do i need to change from 16" to 17" wheels
Old 12-14-2006, 08:48 PM
rxrom's Avatar
Default what do i need to change from 16" to 17" wheels
I have a 98 non-ws6 trans am with chrome 16" wheels. I want to upgrade to 17". What do i need to change to make the speedomer acurate? Is there anything else i need to do. I want to use stock WS6 wheels.
Thanks
Roman
Old 12-14-2006, 08:54 PM
skatinjay27's Avatar
nothing, when you go to a 17 your tires will be a smaller profile and the overall diamater will still be the same.
Old 12-14-2006, 11:00 PM
h.o.ls1's Avatar
Old 12-14-2006, 11:05 PM
Eurosouth's Avatar
Thanks
Roman
Just make sure that the tires you get have an 25.7 in. overall diameter to keep the spedometer accurate. The tire size to achieve this is 275/40 rim 17.
Good Luck,
Cheers!
Old 12-15-2006, 09:33 AM
red87iroc's Avatar
Both of the above are correct. If you are looking for a set of polised WS6 wheels with 275-40-17 tires, PM me, as I have a set for sale!
Old 12-15-2006, 01:13 PM
cocimitch's Avatar
As long as overall tire size stays the same, the wheel diameter doesn't matter
Go For It!!
Old 12-15-2006, 02:00 PM
'Trust''s Avatar
Originally Posted by cocimitch
As long as overall tire diameter stays the same, the wheel diameter doesn't matter
Go For It!!
Fixd. Just so he doesn't get confused.
Old 12-15-2006, 04:18 PM
Asmodeus's Avatar
http://www.discounttiredirect.com/di...foTireMath.jsp
