Rering or R&R/bore 2000 z28
Im kinda stuck in between a rock and a hard place. My camaro is my primary means of transportation but I can get around by other means.
Burning about a quart of oil every two gas tanks yet I still have some damn good power behind the beast. I have done compression tests and it seems the rings have gone bad on at least the back driver side cylinders because it takes longer to build compression on the back side.
I know that the ls1 uses piston sleeves in the block so its not like your regular rebuild where you would bore out the cylinder walls. From what I understand I would need to bore out the sleeves? If anyone has some experience or good info on this part that would be great
Now the other possibility is just to get the sleeves honed and rering the pistons but this is also dependent on the status of the sleeves. They could or could not be scarred.
If anyone has any experience with this situation and has found a decent priced way to do so please let me know.
Really open for suggestions for this one as I am new to this, thanks!
