ppl with FAST 90 THROTTLE BODY please come in
Originally Posted by PewterY2KZ28
I ran this spring to keep tension on my FAST TB... Worked perfectly... and yes,, the shorter valley bolts will prevent you from cracking the bottom of the intake..
[IMG][/IMG]
[IMG][/IMG]
[QUOTE=PewterY2KZ28]I ran this spring to keep tension on my FAST TB... Worked perfectly... and yes,, the shorter valley bolts will prevent you from cracking the bottom of the intake..[QUOTE]
I need to do the same with mine, I cannot tell if my foot is on the throttle or not because there is zero spring tension. I havnt had mine stick open yet but being a six speed car it sure makes driving a pain when you cant feel any tension on the throttle pedal.
If I could buy it over again I would go with the Nick williams unit.
