MAF durability
Location: depends on the season, England, Slovakia, Hungary, Finland or Russia
MAF durability
Hi guys, Im in the process of squeezing an '04 GTO engine into an offroad buggy and I wondered how you find the durability of the MAF sensor? is it prone to failure with excess vibration?
sorry if this is a dumb question for you guys but the motors are new to us
Cheers
Jez
Cheers
Jez
Just mak sure its not directly mounted VIA metal to something like say a fraem rail and that you use rubber or silicone couplers with a bit of room for mvoement on both ends it should be fine. Also use a good quality airfilter like a donalson black wing or similar. K&N filters lets to much dirt it.
we can do that - thanks
next issue is deciding on a trans and seeing if we can make the motor run underwater
