Made my decision... 370 iron block
Old 12-21-2006, 11:06 PM
BirdmanLS1's Avatar
Default Made my decision... 370 iron block
Ok well i have talked to Jon at speed inc. (always been very helpful), and ive made my decision, im gonna be goin with the iron block 370 and speed inc's twin turbo kit. Im just wondering if my meziere electric water pump would fit on the new block? Its a 6.0L so thats the LS2 block right? I know this is probably a noob question but i just wanted to make sure that i didnt waste $550 on something that wont fit the new block. Thanks,
Old 12-22-2006, 12:32 AM
BirdmanLS1's Avatar
TTT... anyone know about this?
Old 12-22-2006, 05:15 AM
BirdmanLS1's Avatar
Anyone???
Old 12-22-2006, 07:44 AM
digitalsolo's Avatar
Iron 6.0 is either a LQ4 or LQ9; the only difference between those is the rotating assembly (mostly compression). The blocks themself are identical.
Noob.
Old 12-22-2006, 09:43 AM
JRracing's Avatar
I think it will fit just like any other lsx block. No problem.
Old 12-22-2006, 04:17 PM
383ss's Avatar
yes it will fit. running one on mine.
just FYI, the L92 is a different case. i believe you have to run a spacer because of the VVT stuff.
Old 12-23-2006, 02:33 AM
Tom@SpeedInc's Avatar
The block in question is an iron block, we like to run them cause we have yet been given a problem with them structural wise.
The Mezeire water pump will work with this block and turbo system.
Have fun, when you hold WOT in a turbo boosted LS1 car it feels like you go into time warp, rollercoaster? acceloration like a motorcycle
Old 12-25-2006, 04:56 AM
BirdmanLS1's Avatar
Noob.
Ya... i felt stupid when i found out what it was. And yes noob is an appropriate term for me .
Old 12-25-2006, 04:58 AM
BirdmanLS1's Avatar
Yep, hopefully a year from now i will be able to experience that feeling . Thanks for the info guys, glad i didnt waste all that money on my water pump.
Old 12-25-2006, 05:17 AM
PREDATOR-Z's Avatar
Good choice, good alternative to more cubes,
Old 01-08-2007, 12:09 AM
BirdmanLS1's Avatar
Sorry to dig up my semi old thread, but just wondering, since i was on the topic of wondering about the EWP fitting on the new block, is everything on the LS1 block, heads, cam, intake, pullies, wiring, everything compatible with the LQ4 or LQ9 block? Pretty much, is it just a straight up plug and play engine swap, or do i need to get tons of other stuff to make it compatible to drop straight in? I just dont want it to be this difficult ordeal, otherwise ill just stick to the ls1 block. Thanks
Old 01-08-2007, 01:50 AM
PREDATOR-Z's Avatar
The only issue is the alternator bracket. The iron block needs to be drilled for 3rd bolt and tapped. I run mine without this on 2 bolts with no issues, I just check the 2 bolt's tightness once in a while.
