A little help please!!!
Working on 2000 C5 Corvette.
I'm getting a couple of codes on the Vette. They are: P 1120
P 1220
P 1516.
What do you think I should do. I Pulled off the Vaccum lines at the throttle body and the one that's on the pass. front of the intake. I capped them off. I cleaned the air intake boot, and wipped out the inside of the throttlw body. And now, my car is in "Reduces Engine Power" and I have these codes... Please help. I just want my car to run...
Thanks
P 1220
P 1516.
Thanks
First things first, your sig describes a bad *** setup, (and further noticing your location) that without stepping on anybody's toes, obviously has been tuned to some degree being that this is an A4, and with that setup probably wouldn't be too happy of a camper untuned. With that said, the original stalling, was this in P/N? or Drive, or both? Can you further describe speeds, load conditions when this stalling happened. Most likely the cause is the airflow tables and or spark tables being slightly off. This just happens to be one of the most time consuming parts of a tune on a bad *** A4 setup like this. Matters are not any better given the electronic throttlebody. This is where a Moates Road Runner really shines to nail down a tune like this. I would put the vaccuum lines back on to start.
I pulled off the driver's side valve cover. Yes, well, I found our little problem... #7 cylinder rocker pedistol is broken. I can't believe it. I'll call Texas Speed on Wednesday. I'm sure Jason, and Jon will take care of me.. I'll let you guys know how it goes. The motor, heads rear-end and tranny only have 5 miles on it.
