I give up... part numbers for a ls6 intake to a ls1 coolant bypass #
Old 12-26-2006, 05:20 PM
SSJoe15's Avatar
Default I give up... part numbers for a ls6 intake to a ls1 coolant bypass #
hello i have been serching for the part numbers for the coolant plugs and the front bypass hose for my ls1 because i am installing a ls6 intake now. anywho i would like to order the parts for GMpartsdirect.com. i can find some old part numbers that dont work. so if anyone can help it would be much appriceated.
thanks, joe
Old 12-26-2006, 05:40 PM
Ferocity02's Avatar
LS6 coolant rossover pipe: 12568478
LS1/LS6 steam pipe plugs: 12562788
I'd personally run two of the crossover pipes, one in back and one in the front, this way the back of the heads get cooled also. Just run a piece of 1/4" coolant hose from the back crossover to the front, and use a T-fitting to connect it to the front pipe. This is what I did on my 427 and it worked awesome!
Old 12-26-2006, 05:43 PM
brad8266's Avatar
Just grind down the bottom ridges on the ls6 intake and forget the coolant lines.
Old 12-26-2006, 06:01 PM
2001NBMZ28's Avatar
GM constantly changes the PN's for them, latest are posted here somewhere.
Old 12-26-2006, 06:07 PM
98hardtopZ's Avatar
i couldnt find it on gmpartsdirect either man, i called thunderracing and they hooked me up tho...
Old 12-26-2006, 06:54 PM
00454sscamaro's Avatar
or if you have alot of spare time you could fab these-
Old 12-26-2006, 08:12 PM
SSJoe15's Avatar
great thanks for the info. i will try thunder racing tomorrow.
thanks, joe
Quick Reply: I give up... part numbers for a ls6 intake to a ls1 coolant bypass #
