weights of clutches
Old 01-02-2007, 01:35 PM
68birdls1's Avatar
Default weights of clutches
hey guys, i was just searchin around trin to see if could find any weights of clutch assembly and i am just not having much luck. from what i have found out so far is that the ls7 clutch and flywheel weigh in right about 60 lbs. the ls1 and ls6 are 50 lbs, but other than that i cant find any other weights of any aftermarket clutch assemblies. so guys if yall have any info please post up so we can get an idea of weighs what? thanks alot
daniel
Old 01-02-2007, 07:43 PM
68birdls1's Avatar
no one has ever weighed there stuff?
Old 01-02-2007, 07:51 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Ram Powergrip HD clutch, pressure plate, billet steel flywheel, pressure plate bolts: 58 lbs.
RPS Stage III Clutch, pressure plate, Cyn-r-g aluminum flywheel, pressure plate bolts: 37 lbs.
I never weighed the stock LS6 clutch that was in my car, but it felt every bit as heavy as the Ram Powergrip.
Old 01-02-2007, 08:01 PM
68birdls1's Avatar
awesome, thats some great info... i apprecaite it so much bud! i hope more will respond to this
