383 lt1 fuel pump reccomendation
ok i need some help here, fuel systems are not my forte' if you will, but im running a NA 383 LT1 right around 500 horses but im still on my stock fuel pump, and i have noticed im not making the fuel pressure im not supposed to be, and have found out that it is because of my fuel pump. but the thing is, i have absolutely no idea as to what fuel pump to go with. comments are greatly appreciated in this matter, and i WILL be procharging it in the future, so a nice setup for that would be appreciated also, i would rather setup the fuel system for that right now than later. thanks fellas
What kinda power do you plan to make? A Walbro 340 will be plenty for the motor now but you may need to go to 2 or a external pump for the blower setup. You can give me a call with your setup and info and I can help you figure out what you will need.
Nate
Nate
