What clutch/flywheel should I get?
Old 01-03-2007, 07:41 PM
L67toLS1's Avatar
Default What clutch/flywheel should I get?
Car is all stock now, and will be I/E/Tune car at most when finished. Which clutch/flywheel should I go with?
Thanks!
Newb
Old 01-04-2007, 01:47 AM
BirdmanLS1's Avatar
hmm... look into gettin a textralia OZ700SB
Old 01-04-2007, 01:56 AM
LSGunZ28's Avatar
if you dont plan on going over 425 RWHP - 450 RWHP get the LS7 clutch, and if you plan on drag racing DONT get the Aluminum flywheel.
Old 01-04-2007, 02:08 AM
TwistedSS's Avatar
+1 for all of that. A big heavy flywheel will help you at the drag stip, more rotating mass means less bog down on RPM's when you launch. But a big heavy flywheel may cost you 1-2 MPH in the trap...Maybe...
The LS7 clutch is great for a mildly modified car making less than 450hp. Stock pedal feel, no chatter, great holding pressure, long life.
