What is the optimal fuel rail feed setup?
Old 01-06-2007, 12:45 AM
FastKat's Avatar
Default What is the optimal fuel rail feed setup?
It seems like guys running FI always run their fuel line into the back of one rail and then have a crossover from the front of one rail to the front of the other other. Does this give some of the injectors more pressure than others?
What would be the optimal injector setup, short of running a separate line to each injector?
Which gives you a more consistent pressure accross all of the injectors... a return style or a returnless style setup?
Sorry I don't know much about fueling so these questions might be common knowledge already. -Dave
Old 01-06-2007, 07:17 AM
dschmittie1's Avatar
my understanding it the best thing you can do is have your feed line come up to a Y feed that back of both fuel rails. Then come out the front of both rail to an ajustable fuel preasure regulator and then return to the tank
Old 01-06-2007, 10:26 AM
FastKat's Avatar
Ahh, that's pretty much exactly what I wanted to hear. Any other opinions/experience?
Also, will that setup give the front injectors (#1 and #2) or the rear cylinders (#7 and #8) more fuel pressure?
Thanks, -Dave
Old 01-06-2007, 10:42 AM
Nope preasure will be the same through the rail. This is what I am currently doing to my car.
