Sponsored by: DashLynx
Anybody know the thickness needed for double sided sticky tape, for CME Rear Valance?
Old 01-06-2007, 12:03 PM
TuffSS's Avatar
Default Anybody know the thickness needed for double sided sticky tape, for CME Rear Valance?
I have a CME rear valance that I need to install in the coming weeks and I received no attaching stuff with it. The 3 little plastic plugs won't be a big issue to locate, but I am real curious as to how thick the double sided sticky foam tape stuff needs to be. I want this nice and tight up to the bumper cover so I can't run to thick and if to thin it won't make contact.
Anybody with CME knowledge know????
Really appreciate any help............
Old 01-07-2007, 12:08 AM
6LITEREATER's Avatar
Steve, toofazt, just mounted his with some doublesided 3M tape from AutoZone...
https://ls1tech.com/forums/appearance-detailing/636037-put-cme-56k-warning.html
Old 01-07-2007, 11:09 AM
TuffSS's Avatar
Awesome, thanks much for the info/link DEMONBIRD. I appreciate it.........
Old 01-08-2007, 08:49 PM
SVT THIS's Avatar
I actually went to the Chevrolet dealership and bought soe double sided tape use to put body molding on. Just make sure you clean all surfaces touching the tape with alcohol. I would also recommend using a couple small screws to hold everything in place as well, it may sag a bit if not.
Old 01-09-2007, 06:58 PM
TuffSS's Avatar
Thanks much SVT THIS, appreciate the info. I was wondering about adding any screws.
Quick Reply: Anybody know the thickness needed for double sided sticky tape, for CME Rear Valance?
