are all 02-04 zo6 pushrods 7.45?
Old 01-07-2007, 01:29 PM
eric01ss's Avatar
Default are all 02-04 zo6 pushrods 7.45?
are they all the same length?
Old 01-07-2007, 02:07 PM
hammertime's Avatar
LS1 and LS6 engines use the exact same length pushrods.
LS6 engines have a taller valve to make up for a smaller base circle on the cam.
Old 01-07-2007, 03:04 PM
408 z28's Avatar
not trying to thread jack but if the ls6 has taller valves to make up for the smaller base circle than what size pushrods would you need to run a ls6 cam in a ls1 motor?
Thanks
Old 01-07-2007, 08:03 PM
kenp's Avatar
All things being equal, to keep the same lifter preload, you would need a slightly longer pushrod. You will find that if you do a search on the zo6 cam, lots of people have installed them in their LS1 with oem length pushrods. You will also find the difference in the valve stem heights. I can't remember what it is right off hand.
Old 01-07-2007, 10:00 PM
oange ss's Avatar
LS1Tech 10 Year
6mm = .0236
Old 01-07-2007, 10:39 PM
Smitty's '04 GTO's Avatar
Stock pushrod length in LS1 and LS6's are 7.400. The hollow-stem ZO6 valves are .6mm longer which is about .0236; divide that by the 1.7 ratio of the rockers and you get approx .014 that you need to add to a pushrod length to run ZO6 cam in an LS1. Since they are only available in + or - .025 increments, 7.425 would be a good length.
Or, you could use a length checker to verify...
Old 01-07-2007, 10:49 PM
408 z28's Avatar
thanks guys...i did some research and gm says to use a 7.450 pushrod
