point me in the right direction
hey guys,
i want to build a motor and perfom a swap and go FI (more than likely turbo).
my goal is to go for 600-700hp.
im pretty set on doing a 383 stroker to begin w/ because of the cost and being sure i can reach my goal pretty easy.
the car is an a4, with a 3500 stall and 3.73 gears.
ive been searching the forums for ideas on other peoples builds but im still hungry for information on what is involved and how to do it. Is there any materials you guys would recommend that i can read up on?
I found the 383 build up on the GMHP and have been reading through it.
This build has been done as a rebuild and they suggested going with a rotating assembly package - i found that lunati has a few starting around $3500 but I think i can get an assembled short block for around $4700.
i see the lunati assemblies can be had w/ the different configurations for different CRs.
Few questions this has raised:
a. Are the listed CRs w/ stock heads?
b. could i purchase the 10.5 compression setup, install it and then change the heads to go for a lower CR. That way having the best of both worlds?
c. do you guys recommend doing the build myself or purchasing the assembled short block?
any help is greatly appreciated!
i hadnt read it before you suggested, but afterwards it hasnt changed my opinion much.
I already knew about the cost and that it would be something else on the street.
the car is going to be a WW (weekend warrior) / track car. My thought is that I could always start low and move up as my experience grows.
what would the starting HP be for a basic 383?
