What do I need for clutch replacement?
I ordered the LS7 clutchkit, which comes with LS7 clutch/LS2 flywheel/pressure plate, I was just wondering what else I needed....pilot bearing and updated slave cylinder? Is that all?
James
James
You may want to invest in a trans jack...found a great one at Harbor Freight for 50 bucks. HUGE time saver. You'll also need a clutch alignment tool (AutoZone, less than five bucks) new pilot bearing, (reccomend pilot bering puller also) some locktite (blue or red), a little axle grease (or white lithium), torque wrench, assorted sockets, extensions, brake fluid (for clutch system, get the big bottle), depending on mileage, i'd replace the master cylinder also. It would also be wise to do the drill mod.
Matt
Matt
