Firebird, Friday 1/12
Originally Posted by chuck01
What are the rules regarding sub 13 sec cars?
Unless you're running N20, then you need a jacket...
Basic NHRA stuff
High on diesel fumes
Under 14.0 needs a helmet, under 13.0 needs a DS loop, under 12.0 has "special requirements", not sure what that means. Also, any aftermarket power adder (turbo, s/c, nitrous) you need an approved fire jacket.
http://www.firebirdraceway.com/06web...reetdrags.html
Helmets: Drivers of all vehicles running 13.99 or quicker, and ALL convertibles regardless of E.T., must wear an SFI-approved helmet with a Snell rating of 95 or newer. Passengers in convertibles running 14.00 and slower must also wear an approved helmet. (Note: DOT-only helmets are not permitted. SFI-approved helmets are not permitted if the Snell label inside the helmet is missing or illegible. In other words, a Snell-rating on the outside of the helmet is not good enough.)
If your rear-wheel-drive vehicle is capable of running quicker than 13.00 in the quarter-mile, a driveshaft loop is required. Consult with our Tech Inspectors for specifics.
If your vehicle is capable of running quicker than 12.00 in the quarter-mile, please consult with our Tech Inspectors for additional safety equipment requirements.
As of February 1, 2006 all vehicles with an aftermarket power adder, (nitrous, turbocharger, or supercharger) will be required to wear an SFI approved fire jacket
Originally Posted by thunder550
They don't have helmets at the track. DS Loop = Driveshaft loop - keeps your driveshaft from pole vaulting your car if it breaks.
Thank you
