fuel line questions
Old 01-11-2007, 10:10 AM
WheelsUp84z's Avatar
Default fuel line questions
if running a fuel pump with a bypass regulator will i need to run a return line back to the tank from the regulator at the carb feed line? this is a BG220PS fuel pump (220gph @ 15 psi) for a carbed motor. one of my buddies in airframes is hooking me up with some hardline for my fuel system and was just wondering if i needed some for the return all the way from the regulator or just from the bypass on the pump itself, or both.
Old 01-11-2007, 11:20 AM
Nasty N8's Avatar
You will only need one regulator. If the BG has one built in just run the return from there and the feed right to the carb.
Nate
