running in SD mode
Old 01-12-2007, 06:08 PM
busta9876's Avatar
Default running in SD mode
Could I remove my MAF, hook up an intake air temp sensor to pins A and B of the MAF connector and then disable MAF related DTC's in the PCM and effectivly run in SD mode? Will it enter closed loope? anyone ever try this?
this is truck 5.3L engine swap by the way.
Old 01-12-2007, 06:26 PM
LS1TECH Sponsor
foff667's Avatar
http://www.hptuners.com/forum/showthread.php?t=8994
heres a good read about open/closed loop & SD
