LS1 style engines to old style trans(th350, 400, 2004r, 700r4, 4l60e)
Old 01-12-2007, 11:26 PM
jay_lt4's Avatar
Default LS1 style engines to old style trans(th350, 400, 2004r, 700r4, 4l60e)
someone make this a sticky
here are the facts about fitting an old style trans to the gen3 engines
1. the gm gen1,2 trans will bolt to the gen3 engines but you only use 5 bolts, the gen 3 engines do not use the middle bellhousing bolt on the pass side( no big deal)
2. you do not need a special flexplate, the curved 4.8,5.3,LS1- just need the t/c bolt holes ovaled out a bit and the 5.3 flex plates have a set of holes that match the small gm t/c bolt pattern perfect
- the 6.0 flat flex plate has the same t/c holes as the large gm pattern(th400 and most aftermarket th350 converters that have a dual t/c bolt pattern on them)
3. you need to use a crankshaft spacer when using a gen1,2 trans and converter there are 2 types:
- hughes gen3 crankshaft spacer part # hup-3795 $44 from summit/jegs, this spacer must be used with the curved 4.8,5.3,LS1 flexplates
- gm stock 6.0 crankshaft spacer 12563532 and longer bolts 12563533, this spacer can be used with either the flat or curved flexplate ( if using the curved style flexplate the flexplate goes on the crank first then the spacer goes on then the bolts, if using the flat 6.0 flexplate the spacer goes on the crankshaft first then the flexplate then the bolts)
i have used both style spacers, on several 5.3,LS1, 6.0 swaps and have not had any problems with either set up
jay_lt4 is offline
Old 01-13-2007, 01:35 AM
monkey11's Avatar
hey great job!! I've been looking for this, will help alot. +1 for making it a sticky. What about T/C, isn't the 700 and 4L60E t/c the same? and what about TV cables (bowtie overdrives) ??Pictures may help make this a sticky!!
monkey11 is offline
Old 01-13-2007, 03:58 AM
DanZ28's Avatar
You also have the option to buy an LS1 converter built for a TH350/400 and not use any spacers at all. But it's good to see all the info in one place instead or reading through 10 pages of the sticky/FAQ above, so good write up .
Dan
DanZ28 is offline
Old 01-19-2007, 10:52 AM
jay_lt4's Avatar
how do you get something sticky'd,, there are more post's about this same topic on here all the time, this is the plain simple answer to all the ls1/th350,400 questions
jay_lt4 is offline
Old 01-19-2007, 11:35 AM
Vcious04's Avatar
Good luck making this a sticky and using summit/jegs info/pricing..
Just leave the part # for the adapter. just my .02
Vcious04 is offline
Old 01-19-2007, 12:38 PM
6techniques's Avatar
Yeah, thats what I was thinking too...Its just the law of the land!
Very good info though, I def learned a bit!
6techniques is offline
Old 01-19-2007, 06:03 PM
chevydad's Avatar
if i had access to all three types of flexplates (ls1,5.3,6.0) and was mating a th350 to a 01 6.0, which would be the better or easier flexplate to start with?
chevydad is offline
Old 01-30-2007, 08:21 PM
SatanzWS6's Avatar
great. all the info i needed. thanx man.
SatanzWS6 is offline
Old 02-11-2007, 08:21 PM
the_merv's Avatar
What Converters can you use though.. if you get a LT1 4L60E to go on a LS1, can you use the LT1 Convertor with the 5.3 Flexplate, and a Spacer?
the_merv is offline
Old 02-11-2007, 09:17 PM
jay_lt4's Avatar
you can use the lt1 4l60e converters and the hughes spacer and 5.3 curved flexplate
jay_lt4 is offline
Old 02-11-2007, 10:47 PM
the_merv's Avatar
I didn't find anything on Summit, anyone found any kind of spacer anywhere?
I found this:
http://cgi.ebay.com/ebaymotors/ws/eB...3841193&rd=1,1
the_merv is offline
Old 02-12-2007, 07:02 AM
jay_lt4's Avatar
here is the hughes spacer from summit:
http://store.summitracing.com/partde...5&autoview=sku
jay_lt4 is offline
Old 03-05-2007, 02:09 AM
Dirty 30's Avatar
TTT, Great info.
Dirty 30 is offline
Old 03-05-2007, 05:49 AM
monkey11's Avatar
What about if i go from a t-56 to a 700 R4, with a 2002 camaro? how do i correct the speed sensor?? i know yank sells the correct reloctor ring but can i correct it with a tune instead?? im not sure about this?
monkey11 is offline
Old 03-05-2007, 07:27 PM
Dirty 30's Avatar
Just picked up spacer, pics...
Dirty 30 is offline
Old 03-05-2007, 08:25 PM
Sweet71's Avatar
Good info im just about to do one
Sweet71 is offline
Old 03-28-2007, 06:34 PM
JeevesRules's Avatar
was doing a conversion myself and found this as one of the best laidout posts in the subject ... just a bump for those looking to save on the legwork
JeevesRules is offline
Old 03-28-2007, 07:11 PM
LS1MCSS's Avatar
I have the Hughes spacer ordered from Summit. It should be here tomorrow.
LS1MCSS is offline
Old 03-28-2007, 10:15 PM
kill_machine85's Avatar
awesome knowledge
kill_machine85 is offline
Old 03-30-2007, 02:51 AM
beefcake's Avatar
Default wow
this is very very helpful this should be a stick reguardless of the rules
beefcake is offline
Quick Reply: LS1 style engines to old style trans(th350, 400, 2004r, 700r4, 4l60e)
