Turbo Exhust Setup
Turbo Exhust Setup
Ok as you can see in the pic of my OFI kit that should arrive shortly, it connects to the stock catback.
Well I have a full welded setup, Catless JBA mid pipe with welded in Dynomax race bullets. Well I can not use this now.
So here is what I was thinking and wanted to get feed back first. Where it makes that turn to connect to the stock catback I cut. Run a 3in stright peice of pipe (Size of DP also) to a Muffler (Which one) and to a single corsa tip.
Now which muffler should I use? I have
