I have a 98 car but will be using 99 Style coil packs
Of course the 98 had perimiter valve covers . but now going to new heads it will be center bolt. The 98 coil packs bolt directly to the 98 covers , not to a bracket like the 99's do .
I plan to use 99 center bolt covers and coilpacks and brackets , but wonder if they will plug into the 98 harness on the car with out problems , is the wiring the same?
9 Second Club/LS1TECH Sponsor
The wiring is the same. They will plug right in at the gray/white connector.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
Thanks John , I was going to email you about this and about the wiring I need soon .
Thanks Jason from G Force !
