6.0 Escalade motor in my 59 impala have ?s
I am buying a new escalade motor to put in my 59, I plan on changing the oil pan to the shorter style, and would like to use one of the bbk intakes mainly cause I want to get it chrome plated, is there a year I should stay away from and will these parts bolt on with any probs, I have access to almost any part I will need just need to know if there is any major issues I will run into. Thanks for any help. Yes im a newb.
Welcome to the forum! I love to see these great motors in the vintage 50s rides. First suggestion I have for you is to read through the Sticky threads at the top of the forum. Many many questions asked and answered there. Also check out the project pages at Street and Performance (www.hotrodlane.cc). I believe they have a Chevy project from similar vintage as yours that will give you ideas. As for the Escalade motors, I will defer to others on that one, not sure on the PCM compatibility. Another great resource for wiring and pcms is John at Speartech.com. He can help make your swap plug and play. I hope you will find someplace to do an online journal and keep us posted on your progress. We really like pictures!
Pat
Originally Posted by Stu Cool
ImpalaRider,
Pat
Pat
sawzall wielding director
Well in order to put the car style manifold on you will have to make some changes. You can either convert to car accys and brackets or you have to move the idler pulley by the alt and change the output of the water pump. The output of the truck water pump will hit the TB.
As far as what to stay away from, the 99-00 6.0L truck motors have iron heads that do not flow as well.
