Drill Mod Help????
Drill Mod Help????
I've read about the drill mod, my question is what does it do in terms of actual pedal feel and engagement of the clutch? I've replaced the clutch master and slave and put a new clutch in, but didnt do the mod. I found out about it afterwards, but if it will help the pedal feel, I'll dive back in and do it.
Thanks.
Thanks.
It allows the fluid to pass through the line faster. There is a restriction in the line that keeps it from moving as fast as it could. The restriction is suppose to be for smoother engagment, but it winds up hindering high rpm shifting, and doesn't let the clutch grab as hard as it could when you release the clutch.
Drill Mod
http://www.installuniversity.com/ins...sity/index.htm
Check this link out and read step 16.
