Injector Tuning...
Old 01-22-2007, 12:02 PM
LostCauseZ06's Avatar
Default Injector Tuning...
since i dont wanna hijack the SVO thread anymore... does ANYBODY have racetronix 42# injectors in their car? can they send me their IFR table?? i have no clue what i need to change this stuff to and id rather not **** it up
injector specs:
Delphi/Lucas 42# High Impedence Fuel Injectors
-Static Flow Rate: 42.29 lb/hr @ 43.5PSI
-Static Flow Rate: 48.83 lb/hr @ 58.0PSI
-Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
-Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
this is what im coming up with??
MAP (kPa) 0 5 10 15 202530354045505560657075 80
Injector Flow (g/sec) 6.15258 6.190924745 6.229033451 6.266910425 6.304559843 6.341985758 6.379192104 6.4161827 6.452961256 6.489531379 6.525896571 6.56206024 6.5980257 6.633796174 6.6693748 6.704764631 6.739968642
Injector Flow (lb/hr) 48.83086114 49.13518988 49.43764526 49.73826147 50.03707164 50.33410795 50.62940161 50.92298295 51.2148814 51.50512559 51.79374332 52.08076163 52.36620682 52.65010447 52.9324795 53.21335613 53.49275797
Injector Flow (lb/min) 0.813847686 0.818919831 0.823960754 0.828971024 0.833951194 0.838901799 0.84382336 0.848716383 0.853581357 0.85841876 0.863229055 0.868012694 0.872770114 0.877501741 0.882207992 0.886889269 0.891545966
Old 01-22-2007, 01:55 PM
SSpdDmon's Avatar
I replied in the other thread...
Old 01-22-2007, 04:00 PM
dude thanks a ton!! put the injectors in at lunch, reflashed the tune.. and holy ******* shiit... i hit the gas @ 4k on the freeway and aboutshit my pants when i felt the car pull ALL THE WAY to 7k for the first time since the engine build...
note to self.. never try and convince myself that stock injectors are big enough for a 408 ever every again
Old 01-22-2007, 05:56 PM
SSpdDmon's Avatar
no problem....glad we could help
