quick question about retainers, not sure what i need
I bought some valve springs recently.. they are behive with an orange stripe on them. I am told they are 03+ LS6 springs with a max lift of .580..
question #1.. does the above seem right?
question #2.. what retainers can I use with these? will stock LS6 or LS1 work? or do i need some other type.
The stock retainers will work with the valve springs. I am not sure on the color code though. The LS6 springs that I bought from GM are completely yellow. They are rated 90 lbs. @1.8" seat pressure and 280 lbs. @ 1.25" open pressure, with a max .570" lift.
