how to change the TA fog lights?
If you have a small enough arm you can simple open the head light doors(turn on light) and reach down and turn them about a quarter turn and they should pop out. of you replaceing the housing, you need to get under the car and pop out the 3 plastic rivits on the black slopeing trim peice, pull it back and you should be able to reach them . just take a screw driver and pop out the center portion of the rivits out so you can re-use them. hope this helps.
