LS1 cam & spring swap tools
I'm not sure if this is the right place to post this question or not. I was told that there are some sort of rods that are inserted into the block or heads that hold the lifters up while doing a cam swap. Has anyone ever heard of this? If so, where can I get them? I also need an on car valve spring compressor. I would like to go with something that is strong and reliable and does not screw the heads up.
5/16" rod. i think 2' wiil work, i dont remember.
the tim tool will work as well, i made one that was exactly the same and worked great
other than that, you need a 10mm, 8mm, and 24mm sockets, various rachets and extentions, torque wrench, crank pulley puller, spark plug socket, and an air hold3(compression tester with an air compressor)
