egr valve/hose on a 2002????
LS1Tech Administrator
Received 1,493 Likes
Yep, either you are confusing the AIR system for the EGR system, or you have a non-stock EGR system installed for whatever reason.
Easy to tell..... this hose you speak of, does it connect to the top of the intake right behind the throttle body? If not, then you are looking at the AIR system.
