700r4
I have one needs build but it is the later model aux valve body unit. you can have it either way ... burned up or ill build it. Wont be my first or my last (10 year master certified tech) up to you. if your interested ill get u prices if u tell me how u want it built.
700r4
Hi Charlie,
I have one in New Port Richey. It worked well when I removed it $250 if you buy it before the 1st as I am moving my shop and that way I don't have to move it. LMK 727-534-9175
Thanks,Dan
Thanks,Dan
I have one built for quite a bit of HP. High performance clutches, Z-pak, Trans-go shift kit, 4wd case, etc. I have over 2k invested and I'm parting out my car. Local shop (the place to go for trannys) built it and has a warranty on it.
