Chime in if you're actually running an LS4 pump.
Old 01-29-2007, 09:54 AM
Cobra4B's Avatar
Exclamation Chime in if you're actually running an LS4 pump.
https://ls1tech.com/forums/generation-iv-internal-engine/649079-chime-if-you-running-ls4-oil-pump.html
Old 01-29-2007, 10:03 AM
thehammer69's Avatar
Cobra...you should not worry. Your oil cooler will steal away some of your oil output and then dumps it right back to the sump. That should balance out any chance of not enough oil making it back to the sump fast enough.
Hammer
